查看: 7697|回复: 35
绝美照片赏析
发表于 2013-9-2 11:36:03 | 显示全部楼层 |阅读模式
Title Carbonic Orchid Formed By Graphite Crystals
By Shaahin Amini
Description Scanning electron microscopy (SEM) image shows a carbonic orchid formed by various graphite crystals within nickel matrix during solidification of a Ni-C alloy: primary flakes (purple), spheres (yellow) and eutectic flakes (green).
参与人数 1威望 +5 金钱 +60 贡献 +5 收起 理由
以前以后 + 5 + 60 + 5 很给力!
 楼主| 发表于 2013-9-2 11:40:20 | 显示全部楼层
Title   Diamond Pyramid
By   JiaPeng Xu
Description   Topographical view of a growing diamond grain (CVD).
这位应该是中国大陆出生的学者。  发表于 2013-9-3 06:31
 楼主| 发表于 2013-9-2 11:42:34 | 显示全部楼层
Title   Copper Ferns
By   Raymond Thompson
Description   Copper ferns dendrites grown in electrolytic solution while cathodic charging with a copper electrode. Copper-colored cloud appeared in solution and was extracted to determine what it might be. EDS showed it was 95% Cu and 5% Fe, the ferns were just pretty! Taken on Hitachi SEM 2640 in grayscale, the photograph was color adjusted in Microsoft Picture.
 楼主| 发表于 2013-9-2 11:45:53 | 显示全部楼层
Title   Silver Cermet
By   Amit Shyam
Description   This thin film of silver cermet leaves visible facets when sintered on a ceramic substrate at 950 deg Celsius. The facets are caused by evaporation of silver which is close to it melting point of 960 deg Celsius. The film provides a conducting path on an insulating ceramic and has been imaged with differential interference contrast microscopy.
签到天数: 201 天
发表于 2013-9-2 11:49:40 | 显示全部楼层
很奇妙的世界!
 楼主| 发表于 2013-9-2 11:54:40 | 显示全部楼层
Title   Lightweight Steel Dendrites
By   Laura Bartlett
Description   Optical micrograph of a Fe-29%Mn-9%Al-0.3%Si-0.9%C-0.4%Nb steel that was hot rolled and recrystallized. The microstructure consists of recrystallized austenite grains and annealing twins. Niobium carbides appear as bright contrast precipitates pinning recrystallized grains. The image was taken using differential interference contrast imaging and cross-polarized illumination. The specimen was etched with 5% nital and Klemm's reagent.
参与人数 1金钱 +20 贡献 +5 收起 理由
Jasen + 20 + 5 感谢上传
发表于 2013-9-2 12:09:10 | 显示全部楼层
By   JiaPeng Xu
Description   Topographical view of a growing diamond gr ...
艾伦老师,这张图怎么来的,不会是金相图吧。
 楼主| 发表于 2013-9-2 12:49:31 | 显示全部楼层
原图说明没有提到这个问题,铁匠估计是扫描电镜SEM照片。
发表于 2013-9-2 12:52:17 | 显示全部楼层
说明中指出是:SEM图片。
小袁问我的是2楼图片,2楼图片上没有说明是SEM照片。  发表于 2013-9-2 13:42
签到天数: 40 天
发表于 2013-9-2 12:54:25 | 显示全部楼层
微观金相组织与艺术的结合,如沐春风,赏心悦目,美不胜收啊!
 楼主| 发表于 2013-9-2 13:53:28 | 显示全部楼层
Title   Tungsten Carbide in Nickel Silicon Boron Matix on Tool Steel
By   James Tomich
Description   Laser Clad Tungsten Carbide (WC and W2C) in Nickel Silicon Boron Matrix on Tool Steel at 500X magnification.
参与人数 1金钱 +20 贡献 +4 收起 理由
Jasen + 20 + 4 感谢上传
发表于 2013-9-2 13:54:12 | 显示全部楼层
唯一遗憾没有放大倍数。
 楼主| 发表于 2013-9-2 13:57:18 | 显示全部楼层
Title   HfN-based Cermet
By   Tim McKechnie
Description   This micrograph is of a Hf-based cermet after etching with 10% HF / 45% HNO3 / 45% H2O. Image was taken at 20x resolution using a Nikon Model Epiphot 200 microscope with Polaroid camera. Image was taken by Markeeta Smith/ Dr. Daniel Butts.
Jasen + 20 + 5 感谢上传
 楼主| 发表于 2013-9-2 14:16:43 | 显示全部楼层
这个是什么? 也是金相照片吗?这不是个鹿脑袋吗?{:soso_e114:}
Jasen + 20 + 5 感谢上传
 楼主| 发表于 2013-9-2 14:19:47 | 显示全部楼层
嘿嘿,楼上图片我卖了个关子,还真是SEM照片哦,好玩吧?{:soso_e120:} 请见以下说明:
Title   Super Tiny Giraffe Found Grazing in Microscopic Jungle of Ni-Al-C Dendrites
By   Shaahin Amini
Description   SEM image depicts a baby giraffe formed within a jungle of Ni-Al-C dendrites. As the molten alloy was being solidified inside a graphitic crucible, the melt was decanted, leaving behind a little dendrite wetted by a thin molten blanket. The blanket eventually froze and rejected carbon, crystallizing as a graphite cover. The graphitic cover then wrinkled, due to its thermal expansion coefficient mismatch with metallic substrate, creating a faceted network of creases resembling a giraffe's skin patches.
 楼主| 发表于 2013-9-2 14:24:51 | 显示全部楼层
双相不锈钢
Title   Steel in Red and Blue
By   Paul Dawson
Description   Electron backscatter diffraction reveals grain and phase morphology of dual-phase stainless steel LDX-2101. In this false-color image, austenite is red and ferrite is blue. Grains are shaded based on crystallographic orientation. The rolled material exhibits a columnar phase structure with packets of austenitic grains embedded in the ferrite matrix. (in collaboration with A. Poshadel)
Jasen + 20 + 5 感谢上传
 楼主| 发表于 2013-9-2 14:42:21 | 显示全部楼层
金相显微镜下的阳光:
Title   Metallic Sunshine
By   Clemente Parga
Description   SEM Micrograph in EBSD Mode: Micrograph shows a Re-W-Ta-B based alloy cube (top left corner) interaction zone after liquid metal attack by superheated molten stainless steel (Fe-Cr-Ni-C) at 1800 degrees C per 6 minutes. The test was conducted in an induction furnace inside a graphite crucible under an inert argon atmosphere at 2atm absolute pressure.
Jasen + 20 + 5 感谢上传
 楼主| 发表于 2013-9-2 15:08:20 | 显示全部楼层
aaron01 发表于 2013-9-2 14:42
金相显微镜下的阳光:
1800摄氏度,degree C= 摄氏C度哦, 原文如此。
在充2个大气压的氩气的感应炉内,保温了6分钟。
 楼主| 发表于 2013-9-2 15:20:17 | 显示全部楼层
这个像什么?
Title   Niobium Flower
By   David J. Florian-Alagrin
Description   Image the Particles NbB2 10 hours of ball milling. Photo taken with scanning electron microscope (SEM)JSM-6390,amplification 5000.
Jasen + 20 + 5 感谢上传
发表于 2013-9-2 16:09:30 | 显示全部楼层
        以上这些照片都是金相照片吗?我看前面三幅怎么不像呢?希望艾伦配以中文说明,否则老孤等不懂西文的老家伙只能“洋鬼子看戏”了{:soso_e144:}
嘿嘿,铁匠要逼大家操练一下英语哦,过段时间再翻译吧,性急的朋友可以自己查字典  发表于 2013-9-2 16:33
 楼主| 发表于 2013-9-2 17:10:58 | 显示全部楼层
这个帖子里的全部作品都是美国科技刊物JOM(矿物、金属和材料)杂志举办的2013年度金相摄影比赛获奖作品,有的是SEM照片,也有的是光镜下的照片。
这些美到冒泡的照片,震撼到我了,很难想象人家的创造力,忍不住想要分享给大家。
签到天数: 40 天
发表于 2013-9-2 21:13:17 | 显示全部楼层
aaron01 发表于 2013-9-2 17:10
这个帖子里的全部作品都是美国科技刊物JOM(矿物、金属和材料)杂志举办的2013年度金相摄影比赛获奖作品, ...
中国有金相摄影比赛吗?如果没有,适当的时候可以在我们论坛也举办一次哦!
我在想:这些美到销魂的金相组织图片实在是有些浮夸,反应到现实,他们符合技术要求吗?
也许只有不合格的金相才能如此妖艳吧!
签到天数: 76 天
发表于 2013-9-2 21:53:12 | 显示全部楼层
好看,有创意啊{:soso_e100:}
{:soso_e179:}
{:soso_e189:}{:soso_e181:}
签到天数: 449 天
发表于 2013-9-2 23:54:48 | 显示全部楼层
By   Laura Bartlett
Description   Optical micrograph of a F ...
看完了,最喜欢这张了,以前在金相中从没看到过析出的碳化物对晶粒的钉扎。。。
发表于 2013-9-3 01:09:29 | 显示全部楼层
   凑个热闹
aaron01 + 10 看着像水田
签到天数: 3830 天
发表于 2013-9-3 11:11:59 | 显示全部楼层
免费下载的新闻:Micrograph Project Celebrates the Art of Science Micrograph Project Celebrates the Art of Science.pdf (1.76 MB, 下载次数: 54) 截图00.jpg
 楼主| 发表于 2013-9-4 09:38:03 | 显示全部楼层
Title   Tectonics of TiC  碳化钛的结构
By   Mahmood Anwar
Description   Tectonics of TiC micrograph shows the surface morphology of the Ti-6Al-7Nb alloy sample carburized at 1250oC temperatures under inert gas condition. It is observed that surface peak and valley for 6 hour carburization time indicates a compact and matured grain carbide formation.
签到天数: 128 天
发表于 2013-9-7 09:12:59 | 显示全部楼层
象海底世界的珊瑚
签到天数: 28 天
发表于 2013-9-7 17:46:24 | 显示全部楼层
自然的力量真奇妙
签到天数: 96 天
发表于 2013-9-7 21:20:59 | 显示全部楼层
这些照片太美了
终于解冻了
发表于 2013-9-12 23:19:41 | 显示全部楼层
是陶醉的感觉么? 好像我们这个层次的空间比较乱啊,下面的空间倒是很规矩,很美好。
GMT+8, 2025-8-27 20:58 , Processed in 0.191273 second(s), 31 queries .
