查看: 2244|回复: 0
Plane makes emergency landing after passenger tries to open door
发表于 2016-8-30 17:56:42 | 显示全部楼层 |阅读模式
Plane makes emergency landing after passenger tries to open door mid-flight
登录/注册后可看大图
An Alaska Airlines jet passes the air traffic control tower at Los Angles International Airport (LAX) during take-off on April 22, 2013 in Los Angeles, California.
SEATTLE -- An Alaska Airlines flight from New York to Seattle made an emergency landing in Minneapolis on Monday after a passenger tried to open a rear-door mid-flight, CBS affiliate KIRO reported.
The Boeing 737 was on its way from New York’s JFK Airport to Seattle, Washington.
Alaska Airlines confirmed the incident to KIRO.
“We did receive reports that this passenger attempted to access a door at the rear of the aircraft. The passenger was unsuccessful as it is physically impossible to open an aircraft door while the aircraft is pressurized and inflight,” Alaska Airlines spokesperson Halley Knigge said.
Vid from girl on @AlaskaAir flight from NYC to Seattle, delayed bc officials say a man tried to open a door mid-airpic.twitter.com/Ym38Hu0qCz
— Linzi Sheldon (@LinziKIRO7) August 29, 2016
The flight continued on shortly after police escorted the disruptive passenger off the flight.
Minneapolis-St. Paul International Airport Police told KIRO that officers questioned the unruly passenger and determined he presented a danger to himself.
The passenger was taken to a local hospital.
An airport spokeswoman said the suspects name is not being released at this time.
GMT+8, 2025-10-25 21:55 , Processed in 0.140022 second(s), 26 queries .
