查看: 12363|回复: 21
德国KGO真空氮化炉有望设立中国区代理商
签到天数: 55 天
发表于 2016-8-18 10:52:49 | 显示全部楼层 |阅读模式
德国KGO有超过65年的经验在定制工业热处理炉方面的解决方案
KGO GmbH是一家拥有超过65年的经验为行业提供定制炉的设计。KGO GmbH是一家成立于1998年,但可追溯到1948年成立卡明斯基Appartebau。
2000年KGO收购Schott液压,KGO 是一家现代化的、 具有独立的知识产权,可为各种热处理工艺定制从模具炉,全自动气体氮化炉和真空热处理炉。
目前KGO可提供不同尺寸.不同加热方式, 及操作的符合标准得热处理工业炉。
技术创新、质量和服务是KGO享有成功的关键。全球有许多成功案例 ,KGO努力提供这种支持,技术咨询和工程服务,以支持新设备安装以及改造和更新设备。
所有设备产品可以配置先进的过程(大气)控制传感器。数据日志记录系统记录、监控和评估相关的过程数据和可以使用先进的控制系统监测氮化(Kn)和气体碳氮共渗(Kc)
不断的对细节的关注、技术进步、质量和服务是他们成功的关键。KGO总部设立工程和研发部门,不断研究新的控制技术,推进他们的工艺设计。
所有的模型都符合AMD2750E(测)和已经注册使用AMS 2759/6B(气体氮化),2759/10A(两级气体渗氮)和2759/12(铁素体气体碳氮共渗)。
KGO GmbH has more than 65 years of experience providing customized furnace designs to the industry. KGO GmbH was formed in 1998, but traces its legacy back to its founding in 1948 as the Kaminski Appartebau.
In 2000 KGO acquired the intellectual property of Schott Hydraulic GmbH, which expanded their equipment offerings for various applications from mold furnaces to fully automated Gas Nitriding Furnaces and Vacuum Tempering Furnaces.
Today KGO offers a wide array of standard furnace sizes for the heat treatment industry.  The company takes great pride in their ability to customize the standard designs to meet unique requirements in chamber size, furnace operation or heating requirements.
Technical innovation, quality and service characterize the success that KGO has enjoyed. With many success stories on all continents, KGO strives to provide this support, technical advice and engineering services in support of new equipment installations as well as retrofitting and updating equipment produced by others.
All equipment offerings can be configured with advanced sensors for process (atmosphere) control. Data logging systems record, monitor and evaluate the relevant process data and can employ state of the art control systems for monitoring nitriding (Kn) and nitrocarburizing potential (Kc)
Constant attention to detail, technological advancements, quality and service are the keys to their success. KGO operates an Engineering and R & D Department, which constantly examines new control technologies, which advance the art of their design.
All models are compliant to AMD2750E (Pyrometry) and have been certified for use to AMS 2759/6B (Gas Nitriding), 2759/10A (Two Stage Gas Nitriding) and 2759/12 (Ferritic Nitrocarburizing).
氮化炉有效工作尺寸。
DepthWidthHeight
9006006001200 Kg
12009009002500 Kg
18009009003000 Kg
1800120010003500 Kg
2400160015006000 Kg
发表于 2016-8-18 11:10:02 | 显示全部楼层
Jerry,你是要过去吗?
签到天数: 55 天
 楼主| 发表于 2016-8-18 11:15:46 | 显示全部楼层
不知道有没有前途?/
发表于 2016-8-18 11:19:42 | 显示全部楼层
Jer ry 发表于 2016-8-18 11:15
不知道有没有前途?/
Chief Representative 可以做啊,嘿嘿,开山鼻祖。
签到天数: 55 天
 楼主| 发表于 2016-8-18 11:23:16 | 显示全部楼层
关键是市场怎么样?  不了解啊!!回头我把设备的图片晒晒。
发表于 2016-8-18 11:28:08 | 显示全部楼层
氮化是我绝对看好的一个市场,KGO的性价比就不用说了,个人觉得你不用担心市场,努力做的话一定没问题的。
发表于 2016-8-18 13:03:42 | 显示全部楼层
签到天数: 55 天
 楼主| 发表于 2016-8-18 13:34:38 | 显示全部楼层
骑驴者何人 发表于 2016-8-18 13:03
后面的是装载量吗?
是的, 包含料框的重量。
发表于 2016-8-18 13:54:36 | 显示全部楼层
签到天数: 55 天
 楼主| 发表于 2016-8-18 14:44:01 | 显示全部楼层
骑驴者何人 发表于 2016-8-18 13:54
做到6吨的氮化炉也是蛮厉害的  真空的氮化炉吗?
上些图来看看啊
图片1.jpg 18-12-10 的炉子, 带氨裂解器。 真空回火/氮化/氮碳/预氧化/后氧化。最高温度750度。内外冷却。
发表于 2016-8-18 15:56:48 | 显示全部楼层
签到天数: 55 天
 楼主| 发表于 2016-8-18 16:51:07 | 显示全部楼层
骑驴者何人 发表于 2016-8-18 15:56
设备看上去很漂亮
介绍下控制系统就更好了,斯坦格控制系统吗?
是的, 控制系统采用斯坦格SE-609, 上位机软件SE-2000. 最多可设置250 个recipes .可调取生产数据,过程数据及历史报警。
同时, 只要将设备联到网上,可进行远程故障诊断。
签到天数: 2477 天
发表于 2016-8-18 18:25:23 | 显示全部楼层
Jer ry 发表于 2016-8-18 16:51
是的, 控制系统采用斯坦格SE-609, 上位机软件SE-2000. 最多可设置250 个recipes .可调取生产数据,过程 ...
气加热吗
签到天数: 55 天
 楼主| 发表于 2016-8-19 08:01:12 | 显示全部楼层
目前国内使用的都是燃气加热, 不过可以根据客户要求, 使用电加热。
燃气加热的优点就不用说了, 不过会比电加热多10% 的关税出来。
签到天数: 2477 天
发表于 2016-8-19 08:02:36 | 显示全部楼层
燃气加热的优点就不用说了, 不过 ...
嗯   高大上   罐子挺漂亮的    内胆什么材料的
签到天数: 55 天
 楼主| 发表于 2016-8-19 08:15:30 | 显示全部楼层
德标1.4841, 炉内支撑也是同样的材料,支撑高度/水平可任意调节。
发表于 2016-8-19 08:29:02 来自手机 | 显示全部楼层
没汇森的好看,只是直观印象别见怪。
签到天数: 55 天
 楼主| 发表于 2016-8-19 08:51:54 | 显示全部楼层
龟山淬火 发表于 2016-8-19 08:29
没汇森的好看,只是直观印象别见怪。
上个汇森的图片看看? 不过个人认为设备是用来产生价值的, 主要看性价比。。。呵呵!!
签到天数: 2477 天
发表于 2016-8-19 10:05:45 | 显示全部楼层
Jer ry 发表于 2016-8-19 08:51
上个汇森的图片看看? 不过个人认为设备是用来产生价值的, 主要看性价比。。。呵呵!! ...
不瞒您说   我们公司最近要上一个新的氮化炉    您的炉子是我见过最好看的了
估计价格不菲    老板吃不消     还是开了下眼界了   乡下人没见过好东西
签到天数: 55 天
 楼主| 发表于 2016-8-19 10:47:21 | 显示全部楼层
估计价格不菲    老板吃不消 ...
谦虚了,东方...............要看你们工件的热处理要求了, 这个炉子的性能没得说,运行稳定,控制精度非常好。
价格方面还可以。 性价比不错的。 不过交货期要长一点。 德国佬不会为了敢进度牺牲炉子质量的。
如果交货期不急得话, 其它可以了解一下的。
签到天数: 2477 天
发表于 2016-8-19 11:04:05 | 显示全部楼层
Jer ry 发表于 2016-8-19 10:47
谦虚了,东方...............要看你们工件的热处理要求了, 这个炉子的性能没得说,运行稳定,控制精度非 ...
确实不错    待和设备部说说   您这个是国外的东西    国内的售后怎么办呀
签到天数: 55 天
 楼主| 发表于 2016-8-19 12:28:26 | 显示全部楼层
这也是KGO 设立代理商的原因之一。 的售后由国内代理商负责, 有关键的备件库存。
GMT+8, 2025-11-4 19:42 , Processed in 0.140926 second(s), 30 queries .
