查看: 10619|回复: 17
【热招】舍弗勒太仓 热处理工程师~~~新人贴~~
发表于 2016-1-9 18:30:43 | 显示全部楼层 |阅读模式
热处理工艺工程师Heat Treatment Process Engineer(太仓)
职责Responsibilities:
-       Initiate projects toimprove the efficiency of heat treatment technology
-       Provide technicalsupport and process optimization for springs line and big rotary line
-       Luanch new projectfrom technology point of view
-       Support and cooperatewith German colleagues to handle technical issues
要求Requirements:
-       Bachelor degree orabove in heat treatment
-       At least 3 yearsexperience focus on heat treatment process area
-       Good command ofEnglish in both written and spoken
-      Good communication and coordination skills
热处理模具工程师 Heat Treatment Tooling engineer (太仓)
职责Responsibilities:
-       Optimize heattreatment tooling for spring line and big rotary lines
-       Make new concepttooling together with tool designer
-       Optimize new tool tomatch with different furnaces and warm setting projects
-       Responsible formaintenance of tooling set up list
要求Requirements:
-       Bachelor degree inheat treatment or mechanical related
-       At least 3 yearsexperience focus on tooling optimization or munufacturing
-       Good communication andcoordination skills
-       Good command ofEnglish will a plus
同期还有热处理体系方面、设备管理方面岗位放出~~
有意者请发邮件至 2658337457@qq.com
发表于 2016-1-10 10:08:32 | 显示全部楼层
           一看那曲里拐弯儿的洋码,老孤脑壳子都大了
发表于 2016-1-10 18:19:58 | 显示全部楼层
舍弗勒公司不错,顶!
发表于 2016-1-10 18:21:29 | 显示全部楼层
杨工不要勉强自己,你超龄了。
 楼主| 发表于 2016-1-15 16:10:13 | 显示全部楼层
  有人推荐不~~~
 楼主| 发表于 2016-1-15 16:10:32 | 显示全部楼层
龟山淬火 发表于 2016-1-10 18:19
舍弗勒公司不错,顶!
亲,有人推荐不?~
发表于 2016-1-15 16:30:34 | 显示全部楼层
洋文我也看不懂
发表于 2016-1-15 17:21:45 | 显示全部楼层
这个都看不懂,如何去工作呢?
发表于 2016-1-16 13:25:10 来自手机 | 显示全部楼层
这些要求咱搞都没问题,只是年令可能超了。
发表于 2016-2-12 01:53:22 | 显示全部楼层
职责Responsibilities:
Initiateprojects to improve the efficiency of heat treatment technology
开发课题以提高热处理工艺的效能
Providetechnical support and process optimization for springs line and big rotary line
为弹簧生产线和大旋转生产线提供技术支持和工艺优化
Luanch (拼写错误,应该为:launchnew project from technology pointof view
从技术角度开展新课题
Supportand cooperate with German colleagues to handle technical issues
支持和配合德国同事处理技术问题
要求Requirements:
Bachelordegree or above in heat treatment
热处理大学本科及以上学历
At least3 years experience focus on heat treatment process area
至少3年以上热处理工艺领域的工作经验
Goodcommand of English in both written and spoken
良好的英语听说读写能力
Goodcommunication and coordination skills
良好的沟通和协调能力
职责Responsibilities:
Optimizeheat treatment tooling for spring line and big rotary lines
为弹簧生产线和大旋转生产线提供尽可能有效的工装
Make newconcept tooling together with tool designer
与工装设计人员一起制造全新工装
Optimizenew tool to match with different furnaces and warm setting projects
优化新工装,以适应不同的炉子和加热环境
Responsiblefor maintenance of tooling set up list
负责模具的维护工作
要求Requirements:
Bachelordegree in heat treatment or mechanical related
热处理或机械相关专业本科以上学历
At least3 years experience focus on tooling optimization or manufacturing
至少3年以上模具设计或制造领域的工作经验
良好的沟通和协调能力
Goodcommand of English wills a plus
英语良好者优先
发表于 2016-2-17 11:22:53 | 显示全部楼层
操,这是在招聘吗?
签到天数: 317 天
发表于 2016-2-17 11:56:49 | 显示全部楼层
How much ?
发表于 2016-2-17 16:23:52 | 显示全部楼层
孤鸿踏雪 发表于 2016-2-17 11:22
操,这是在招聘吗?
除去外语这块,其他貌似都不是很高的要求孤版何艹之
发表于 2016-2-17 17:43:52 | 显示全部楼层
         工程师去“负责模具的维护工作”?奇葩啊
发表于 2016-2-18 07:53:38 | 显示全部楼层
孤鸿踏雪 发表于 2016-2-17 17:43
工程师去“负责模具的维护工作”?奇葩啊
前面有要求一起制造工装
个人觉得应该是包含模具的
既然参与制作,那么维护也好理解
发表于 2016-2-18 10:19:45 | 显示全部楼层
腊月寒沫 发表于 2016-2-18 07:53
前面有要求一起制造工装
个人觉得应该是包含模具的
既然参与制作,那么维护也好理解 ...
问题的关键在于“参与制作”的内涵啊
发表于 2016-2-29 15:55:38 | 显示全部楼层
孤鸿踏雪 发表于 2016-2-18 10:19
问题的关键在于“参与制作”的内涵啊
这个你应该会明白的
这些模具以前都是我们热处理工程师出图纸
他们那里说参与,应该是
1.热处理的要求基本要求(硬度等)
2.就是关键数据的公差设定,这就是需要热处理大量数据支撑及热处理经验
GMT+8, 2025-9-16 21:14 , Processed in 0.155941 second(s), 32 queries .
