查看: 3896|回复: 4
请教:表面热处理的英文怎么说?
发表于 2013-2-20 14:10:35 | 显示全部楼层 |阅读模式
最好来一段英文解释。
签到天数: 261 天
发表于 2013-2-20 14:50:18 | 显示全部楼层
"induction quenching "or"surface heat-treatment"
是后面的吧  发表于 2013-2-20 14:55
 楼主| 发表于 2013-2-20 14:52:57 | 显示全部楼层
Optical glass polishing by controlled laser surface-heat treatment
AbstractArticle InfoReferences (10)Cited ByMetrics.Abstract
It is shown that optical surfaces traditionally ground in conventional glasses with high coefficients of thermal expansion may be polished by irradiation with a space- and time-controlled uniform CO2 laser beam. Comparisons of a theoretical simulation model of the laser-driven heating process with the experimental results allow us to determine the conditions for successful and reliable use of this technique. The technique can be applied indiscriminately to preheated samples made of different glasses, with any topography, and, of any size in a limited range that depends only on the available laser power.
© 1994 Optical Society of America
 楼主| 发表于 2017-12-15 11:07:01 | 显示全部楼层
大家再看看我当年的贴子。
签到天数: 386 天
发表于 2017-12-17 22:42:04 | 显示全部楼层
这个英文“内容摘要” 讲应用激光技术对玻璃的光学表面进行处理,不是谈我们这个行当的金属零件表面热处理。
对于我们这个行当金属零件的表面热处理,英文笼统的说“case harden”。case harden 可以细分为induction(感应),carburization(渗碳),Nitriding(渗氮),等。
aaron01 + 20 我很赞同
GMT+8, 2025-10-22 02:32 , Processed in 0.153608 second(s), 26 queries .
