查看: 2422|回复: 3
FAG轴承认识
发表于 2014-3-21 13:32:41 | 显示全部楼层 |阅读模式
FAG轴承认识
FAG             X-LIFE               NU214EN1MPAX.C3.H144               GERMANY             125 F.D
怎么读懂这些内容呢?除开厂家及产地
 楼主| 发表于 2014-3-21 14:10:07 | 显示全部楼层
X-life.
Higher cost-effectiveness.
Higher operational reliability.
X-life stands for premium products of the brands INA and FAG and opens up completely new design perspectives:
Under identical operating conditions, the useful life of X-life bearings is significantly longer. Reversely, operating loads can be increased over the same lifetime as before.
Cutting-edge manufacturing technologies enable us to achieve a better and more homogeneous surface over the entire contact surface between rolling element and raceway. The inside design, which has been optimized for its functions with the help of the most advanced analysis and evaluation tools, ensures an optimized contact surface geometry and a more homogeneous load distribution inside the bearing. This means a reduction of the stress on rolling elements and mating raceway if the load remains the same. The resulting advantages are:
a higher dynamic load rating
a higher nominal service life
less friction and lower bearing temperatures
less stress on the lubricant
The optimized characteristics of X-life bearings allow for a boost of productivity, an optimized design space and a weight reduction. In the final analysis, the better price/performance ratio increases the overall economic efficiency of the bearing arrangement.
发表于 2014-3-21 14:39:32 | 显示全部楼层
FAG 厂家            X-LIFE  超长寿命             NU214 短圆柱轴承,内圈无挡边 E 25°接触角N1外圈带1止动槽 MPA 黄铜实体保持架 外圈引导 X尺寸符合国际标准.C3.游隙按C3,H144               GERMANY     产地    125 F.D
别的不知道
参与人数 2金钱 +40 收起 理由
孤鸿踏雪 + 20 感谢支持
村长 + 20 很给力!
签到天数: 229 天
发表于 2014-3-22 18:20:29 | 显示全部楼层
学习了!积极学习新知识!呵呵!
一个人最大的成功就是每天快乐的活着
GMT+8, 2025-6-17 21:07 , Processed in 0.130511 second(s), 27 queries .
